  1. Hi
    I'm using TMPGenc 2.58 and it's wizard to build a batch-list of different AVI's and MPG's to convert into VCD-format (MPEG-1), which is great!
    However - it's a little tiresome to go through the wizards questions for every single file (the options are the same!!). Is there a way of shortcutting this process, i.e. editing the *.tbe file or something else.
    Any ideas ?
    Kind regards - Sogge
    MO, US
    The simple answer is don't use the wizard. Set up the encode for the first movie. Save the project and/or add it to the batch list. Change the filenames in the box. Verify settings, the only things that are likely to change are the things based on the source video (source range, possibly source aspect ratio and interlace mode). Save/add. Repeat until you've added everything.
