is anyone using terapin vcd recorder..how is the quality
does it do vcd from all source like DVD BETA MINIDV VHS
pl share ur views..any good deal going on
thanks
sreni
thanks 4 inputs
sreni -
:P
I had a Terapin for a few months. It records 1.1 version VCD's and it does a good job. But it stoped reading and recording VCD's after about a month and a 1/2 of having it. The instructions says that after 4 hours of running to let it cool off for a while. But I didn't do that. So the may from E-bay gave my money back. I was lucky for that...
[/b] -
CD-R/W drives just aren't as robust as standard CD and DVD drives unfortunately...
I wonder (does anyone know), if the Terapin uses a standard IDE CD-R/W drive?
Regards.Michael Tam
w: Morsels of Evidence -
I've had my Terapin for about 7 months now and it's excellent for what I need. It's basically a VCR that uses VCD's instead of VHS tapes. What's nice is you can tape & then use your computer to remove commericials & reburn shows. I use it primarily for taping my sons shows (he's 2). The quality is good - however it depends on the source even straight from the tv is still good for watching. I think it's even easier then my VCR to use. It just depends on what your going to use it for. Although I haven't tried it I've heard others say it will tape directly from DVD/VHS no problems (ignores macrovision) - so obvisouly a DVD backup would look better than say a VHS backup. There were a few threads a few months back stating that Sam's Club was selling them for $199, but my local Sam's didn't get any (only certain ones did). I got mine off of Ebay. Is it DVD quality NO - IS it wacthable absolutly! As for its use mine is on an average day 2-8 hrs & I've had no problems whatsoever. Would I buy it again??? Yes.
Which is better for speed and performance?
By SIRCOOKS in forum ComputerReplies: 3Last Post: 20th May 2010, 23:03 -
Concerned about PC performance
By mattman1968 in forum ComputerReplies: 4Last Post: 23rd Oct 2008, 11:31 -
FFMpeg performance
By aeroliteflyer in forum DVD RippingReplies: 12Last Post: 18th Mar 2008, 20:47 -
CRYSIS performance
By retroborg in forum Off topicReplies: 4Last Post: 13th Dec 2007, 07:55 -
Still Performance
By crocker5731 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 5th Dec 2007, 11:31
