I've been using my pioneer-104 burner w/ no problems burning vcd's until now..I tried to burn a vcd w/ nero and when it began to burn it said "Invalid field in parameter"...What does this mean..I made sure it wasn't the file, so I tried to burn another vcd that I had already burnt successfully and it gave me the same error...I need some help..Thanks for any help.....
it means what a waste of a good burner
but you can fix it by uninstalling your burning application and then re-installing it ..
it means there is a bad setting in your burning app script or ini or equal. -
I tried uninstalling nero and reinstalling it and the first cd I burn works fine, but after that I get the same error...Is there anyway to edit .ini file or whatever is causing it to mess up...
update your nero to latest version and buy it ... i found referance to that error msg on another forum if you are not using a legal copy -- if that isnt the case , i'm sorry ..
Ok so how will buying the new nero help this problem...Could I just wipe my hard drive and then reinstall everything, would that make it work...Sorry for the hassle, this is just really bugging me...Thanks for the help so far, I appreciate it...
A Pioneer DVD fix it problem
By kenmt in forum DVD & Blu-ray RecordersReplies: 6Last Post: 23rd Jul 2010, 09:03 -
Problem with video out on Pioneer DV-490V
By Benhermies in forum DVD & Blu-ray PlayersReplies: 2Last Post: 23rd Apr 2010, 16:52 -
Pioneer DVR 533HS Problem
By Hollywood_Mike in forum DVD & Blu-ray RecordersReplies: 25Last Post: 13th Aug 2008, 12:35 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 08:20 -
Region problem with Pioneer
By bltprf in forum DVD & Blu-ray WritersReplies: 10Last Post: 28th Jan 2008, 05:36
