Hi
Hope to get some help from the experts here. I want to archive some old vhs tapes onto vcd. I don't know what to buy to do it and don't want to spend a fortune. I have a 500mhz pentium and a 8gb hd (about half full). I understand I may need much more hd capacity to do this but was wondering if there was a way of doing it without this expense. I may not be getting the concept here but I only want to put 750mb onto a cd I don't get why I need 30gb of memory to do it. PLease help.
Cheers
Bluey
bluey9@yahoo.com
If you want to keep the file size low you might want to condider getting a capture card that captures in mpeg format. that can also get pricey however. barring that you would have to capture small portion of video at a time, convert those small portion into mpeg format then delete the original file and start the process over aagin.
What to look for in Video Capture/Software 4 newbie?
By rivrbyte in forum Newbie / General discussionsReplies: 16Last Post: 1st Mar 2010, 13:42 -
Newbie wanting to capture/re-author DVD from old and new sources...
By archaic0 in forum Newbie / General discussionsReplies: 4Last Post: 18th Sep 2009, 16:49 -
Newbie needs help..can't capture video from dig vid cam to computer
By lithnights in forum Newbie / General discussionsReplies: 4Last Post: 8th Mar 2008, 18:08 -
Newbie frame/ field - capture both interlaced fields
By peter bradbeer in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 8th Feb 2008, 14:36 -
Capture in segments...help for newbie!!
By wormdog88 in forum Capturing and VCRReplies: 0Last Post: 10th May 2007, 07:37
