i need to purchase a new VCR to hook up to my Winnov Videum 1000 plus card. I have several older VHS tapes and my current VCR is low end. Any suggestions for a new one. I need one that will put out a good strong signal for the capture card. And be able to handle 2, 4 and 6 hour speeds.
Will -
I would suggest a S-VHS which outputs a s-video signal which is the best quality for VHS and capturing . I think JVC makes them around $130, I'm not sure though.
If you play normal VHS in an SVHS player you still only get normal VHS quality, if your capturing from normal VHS you don't need SVHS
But I do need a strong signal. Someone mentioned something about time correction, but I know nothing about that.Originally Posted by CommanderXJL
Anyone able to help with that?--
Will
Computer video capture vs. vcr to dvd combo?
By Haopengyou in forum Capturing and VCRReplies: 24Last Post: 19th Dec 2015, 00:50 -
Help needed with Video Capture - No VCR recognised on PC
By ULscot in forum Capturing and VCRReplies: 7Last Post: 14th Nov 2010, 13:14 -
How to capture NTSC video from PAL VCR player
By Cyberrock in forum Capturing and VCRReplies: 0Last Post: 28th Sep 2010, 04:36 -
S-Video vs Composite for capture from S-VHS VCR
By HDClown in forum Capturing and VCRReplies: 5Last Post: 23rd Mar 2010, 08:23 -
capture video from VCR
By nbdeb59 in forum Capturing and VCRReplies: 2Last Post: 3rd Jul 2009, 00:57
