  1. that, if there is some way or some web to know the max bitrate suported by your dvd player, mine is samsung m-105
    thanks.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    all dvd players are the same as far as max bit rate supported by a pressed dvd ... as for a burned dvd - it should be the same (same as pressed) , but some have some problems with higher bit rates ...
