I am having problems with TMPG 2.59.I have got an excellent quality avi that i am trying to convert.I have got problems with the video jittering slightly all the way through.I have tried adjusting the priority of the Direct show multimedia file reader up and down.If I set it to a low level I get perfect video but with no audio.If I up the priority I get jittery Video with Audio. Can anyone advise me on the correct settings to convert this AVI so I can play it in my standalone DVD player.
i use tmpg 2.56. i believe that after that (i could be wrong) that you have to have one of three dvd software players installed on your system for it to work correctly.
are you using the correct frame rate? if not this can cause the jitter.
make sure your settings are correct,then try this: http://www.vcdhelp.com/forum/viewtopic.php?t=119210&highlight=
Coverting recorded TS or MPEG recorded from DVB card to XVid Avi...
By MohamedYousri in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2010, 16:38 -
Coverting AVI > Quicktime
By Kakapo in forum Video ConversionReplies: 0Last Post: 30th Jul 2009, 19:39 -
coverting avi problems
By Tbag in forum Video ConversionReplies: 4Last Post: 30th Sep 2007, 06:32 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
