I guess I don't understand something here. I make an SVCD MPEG file, which is 480x480. In any typical media player it displays at 480x480 - why is that? What happened to my 4:3 aspect ratio? Why 480x480?
If I play this same file in PowerDVD, it displays in the 4:3 ratio, but much larger than 480, that's for sure. Why is that? I want it to play at 100%, not enlarged.
I've yet to burn an entire SVCD, just test the MPEG files. Because MPEG will play on either platform, I thought the MPEG files would run in the default system media player, like Windows Media Player.
Does an SVCD require software such as PowerDVD to run, or not?
Thanks, and Happy Holidays.
The vertical lines are interlaced so you require double to get the 240 vertical lines. I get the same when I play back in win media player but is ok when played with PowerDVD or my home DVD player.
Regards.Michael Tam
w: Morsels of Evidence
Help with MP4 commands for aspect ratios
By tigerb in forum Newbie / General discussionsReplies: 3Last Post: 26th Apr 2012, 13:33 -
MPEG-1 on DVD with different aspect ratios
By DRP in forum Authoring (DVD)Replies: 8Last Post: 15th Aug 2010, 02:16 -
iMovie and aspect ratios
By sphinx99 in forum MacReplies: 3Last Post: 10th Mar 2010, 23:18 -
AviSynth & Aspect Ratios
By blazin-j in forum Newbie / General discussionsReplies: 3Last Post: 28th Nov 2008, 13:39 -
Aspect Ratios
By gayclarke in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2007, 15:13
