When I frame serve in VDub, at the Frameserver Mode window I dont have any numbers moving up all I have is the frameserver name which is my avi name, then theres just 3 zeros which dont moveup/change??? Does this mean VDub is not doing anything and that I havent done something beforehand?
When I encode my NBA games on VHS to vcd/svcd, in scenes where view is looking up towards ceiling of stadium and there are the white spotlights, as the camera moves these lights leave a white trail, which is more prminent than on the original video, is there a filter to remove this or do I just have to accept it?
When I start my framersever, and enter the .vdr filename, I then open tmpgenc and open the .vdr and then when I hit start in TMPGEnc the encoding starts and the numbers in the small vdub window start to change.
Blur/Trailing image after driver update
By carlos28355 in forum Media Center PC / MediaCentersReplies: 6Last Post: 3rd Sep 2011, 11:11 -
Encoding trailing effect PAL > NTSC
By KarenM in forum Authoring (DVD)Replies: 0Last Post: 10th Jul 2010, 13:04 -
Movement has a visual distortion (trailing image)
By Twheels in forum Authoring (DVD)Replies: 6Last Post: 6th Sep 2009, 08:59 -
trailing effect on dvd
By D_Shives in forum Authoring (DVD)Replies: 12Last Post: 30th Jun 2008, 07:42 -
Lights-off
By joelson in forum EditingReplies: 1Last Post: 4th Dec 2007, 16:15
