I'll start from scratch. I cannot play AVI files at all. I've installed all the codecs (nimo codec, divx codec, and radium) but it still doesn't work. I've tried DIV fix, still doesn't work. I've tried playing on Media Player and it says "unable to download an appropriate decompressor". Go figure. I've tried installing GSPOT and running the AVI file but it says the audio and video codec is not installed, however, when I checked in the adminstrative tools it says it is installed and running fine. I'm very confused and need to solve this problem. To maybe help you out a bit, I'm running windows 2000 on a government issued laptop (not sure if this will make a difference). Please respond as I need this fixed by New Year's Eve. Thanks.
what codec does gspot say?
have you tried the xvid codec?
what kind of avi(movie cam or dvd rip)
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
confused with avi settings:
By modern saviour in forum Video ConversionReplies: 3Last Post: 4th Oct 2010, 15:52 -
Confused over colorspace (YV12) and DV AVI
By sasuweh in forum Video ConversionReplies: 4Last Post: 30th Sep 2010, 06:34 -
Confused !!! I am trying to convert avi to dvd.
By reneewhite70 in forum Newbie / General discussionsReplies: 7Last Post: 2nd Apr 2009, 15:55 -
Confused about 1080p
By gauche in forum Newbie / General discussionsReplies: 4Last Post: 18th Jan 2009, 09:51
