Hi,
In general, 0ne svcd file is around 2G, and 1 DVDR can hold 4.3G,
so is there any way to put 2 SVCD into 1 DVDR disk?
Thanks.
mpeg2002
Results 1 to 9 of 9
In general, 0ne svcd film is around 2G(2-3 CDs), and 1 DVDR can hold up to 4.3G, so is there any way to put 2 SVCD movies into 1 DVDR disk? (and can be played back on a standalone dvd player)
Thanks.
mpeg2002
Report this post (warez/spam/bash/...) -
Well it would depend on what the bitrate of the audio and video is. If you are using 384kbps audio a streaming bitrate of at least 2000kbps video, then yes you can. If you are using the same audio quality but a higher bitrate like 3500kbps then you might be pushing it depending on how large the video files are.
I have used KDVD Templates to put up to 3 SVCD quality on one DVD-R, this depends on the length of each movies. Most of the time I do put two on DVD-R. Check www.kvcd.net for more information on how to do this.
Bud -
Ultimately it will depend on your DVD player and whether or not it will play SVCD from a DVD-R; some players will only recognize a DVD-R as a DVD-video only.
I have found that 1.3 Mbit - 1.5 Mbit will allow me to put 3 movies on a DVD-R, in a quality level that is perfectly acceptable to me, virtually making the hassle of putting a movie on 2 cd's and getting up in the middle of a movie to change cd's not at all worth it. I just received my 50 pack of DVD-R's so the only thing I'll be burning to CD now is 30-60 minute TV caps. -
Hi, BudOriginally Posted by Bud
I can encode now, but I really don't know how to put them into
1 DVDR and can be played back on a standalone dvd player.
Could you please explain some detail?
Thx and Merry Xmas -
Hi, furball6969Originally Posted by furball6969
I just burn a svcd data structure into a dvdr, my 3 dvd player(2 apex,
1 norcent) ,no one can play, it is too bad?
BTW,could you please info me what kind of player working ok with you
and how to encode/auther them?
Thx and merry Xmas -
I am using an Apex 1200; I happen to be one of the lucky ones that got a model that plays absolutely everything.
I am burning the files in ISO format I.E. just copying the files to the disc. -
O.K.
Regarding the quality, here is my question..
My original file is a divx file, source from a DVD.
The divx file looks very good.
I can:
A.) Re-Encode to DVD format and burn to DVD
or.
B.) Burn the Entire 1.2G SVCD to DVD? If my DVD player will play a SVCD encoded DVD, what advantage is there in coverting to DVD format and burning the DVD instead of burning the SVCD files to DVD? Did I make ANY sense??
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
Question how to put several dvds on one DVDr
By jimdagys in forum Authoring (DVD)Replies: 7Last Post: 24th Nov 2008, 11:29 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 14th Mar 2008, 00:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 19:14
