In another post I reported having trouble capturing uncompressed avi from my Hi8 camera without a lot of frame drops using UleadStudio 6.02. I followed the advice in the posts and made sure my system was appropriately tweaked. Downloaded VirtualDub-now here's the rub...When I try to play back uncompressed avi captured in Virtual Dub I get sound but no video, however I can now suddenly capture avi uncompressed in Ulead without frame drops Which leads me to believe that installing Virtual Dub added some new codecs. Also, I received a warning from VD on its intial run that there were some potentiously dangerous codecs on my system "angel something" that I removed. So being a newbie I am lost in codec confusion and I think that the key to my capture problem lies somewhere there. Are there any utilities that can verify the integrity of the codecs installed on my system or is there a reference for listing known bad -actor-codecs or bad mixes? How do I sort this out and clean it up? Any suggestions as to which codecs I should install and which I should remove?Why would some codecs play havoc with uncompressed avi capture? Any help would be greatly appreciated.
Here's a list of codecs currently installed in my XP system:
Video
apmpg4v1.dll
divx.dll
divx412.dll
divxc32.dll
divxc32f.dll
huffyuv.dll
iccvid.dll
Indeo video 5.11
Indeo video R 3.2 by Intel
ir41_32.ax
iyuv_32.dll
m3jpeg32.dll
Microsoft MPEG-4 Video Codec
msh261.drv
msh263.drv
msrle32.dll
msvidc32.dll
msyuv.dll
tsbyuv.dll
vfcodec.dll
xvid.dll
Audio
imaadp32.acm
msadp32.acm
msg711.acm
msgsm32.acm
tssoft32.acm
DivXa32.acm
Sipro Lab Telecom Audio Codec
Indeo audio software
L3CODECP.ACM
DivXWMA Audio Compressor
Dvacm.acm
lameACM.dll
Windows Media Audio
vorbis.acm
Thanks so much for the help!!!
Results 1 to 1 of 1
DV CODEC for VHS Capture?
By enbidia in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 140Last Post: 24th Feb 2011, 20:11 -
Sony Video Hi-8 Editing Disk Lost. Need Free Capture/Edit Software
By Classic '57 in forum Newbie / General discussionsReplies: 13Last Post: 14th Jun 2010, 22:08 -
lost audio after capture on ads tech dvd express dx2
By allan4371 in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2009, 21:03 -
i have a SBT-TVFM capture card. lost cd when i rebooted pc. need help
By kitty09 in forum ComputerReplies: 1Last Post: 11th Jul 2008, 14:00 -
TV Capture/Convert lost my color?
By WDude in forum Capturing and VCRReplies: 4Last Post: 11th Jan 2008, 16:20
