These are the steps I have been using to create VCDs. I am hoping to streamline the process if anyone has any feedback.
Thanks....![]()
1. Capture DV via a ADS Pyro Firewire from a Sony TRV-315 Digital 8 Camcorder.
2. Create/Produce using Videowave 5 to one or more 10 minute DV-AVI files. I find if I go longer than 10 minutes I run into voice sync issues. The more fading/effect tranisions the more likely sync issues occur.
3. Take the AVI files into TMPEG Encoder to create MPEG1(VCD) or MPEG2(DVD).
4. Use Nero Rom to burn VCD/DVD. For VCDs I use Memorex CD-RW Platinum 650MB/74min and always write at 4x. I am not sure what is with these CD-RW's but I have never had a coaster yet with these CDs.![]()
P4 2.8 Ghz
512 MB RB Ram
2x80 GB Hard Drive
ASUS V8460 Ultra Deluxe
Lite-On CD RW
ADS Pyro Firewire Card
Windows XP Home/Videowave 5 PE/TMPEG Encoder/Nero Burning ROM
Results 1 to 1 of 1
Homac
homac@telusplanet.net
Comments on JVC BR-S525U
By daave in forum RestorationReplies: 0Last Post: 4th Apr 2011, 01:59 -
Need suggestions on SW for creating AVCHD disks
By dditch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 5th Feb 2010, 20:57 -
IE 8 comments
By stiltman in forum ComputerReplies: 31Last Post: 29th Mar 2009, 06:02 -
More or less intelligent comments
By Photogregor in forum Newbie / General discussionsReplies: 22Last Post: 1st Nov 2008, 04:30 -
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 03:43
