I have a movie in .AVI format. When I play it on my computer using MS-Media Player, it plays in wide screen mode (top and bottom of computer screen are black, movie plays in middle of screen, but stretched out to the edges). This is how it should be played.
I have burnt this AVI file to a CD using the VCD wizard in NERO. When I play it on my DVD and TV, it plays fine, except the picture is stretched/chopped to fit the TV screen, (no longer plays in wide screen mode). Everybody's heads are oval and it is quite disturbing when they show close ups.
Anyway, I have tried everything on my DVD to get it to play in wide screen mode, but to no avail. I assume it is caused by the settings I used when I burnt the VCD in Nero. Any ideas how I can fix this ?
I had the same problem with my first Nero VCD. I don't know if there is a setting to change the aspect ratio in Nero, but I would strongly suggest an external encoder such as TMpegEnc.
There are only 10 types of people in the world:
Those who understand binary
and those who don't. -
first of all don't convert it with nero this sucks i had the same problem, TMpegEnc will do the job more than fine, plz remember to convert it to the right fps so if you live in europe use pal 25fps otherwise use ntsc, if you burn the movie check if its burned pal or ntsc, if you do this it will probably have the same layout as the original avi.
hope to have helped you
greetzyou be dead -
Also, NTSC can be 29.97fps or 23.976fps for VCD.
Hope That Helps!!!:P
Thanks for the words of wisdom! I am glad its not just me!
So I am now using TMPGEnc to convert. I am confused about the fps - you mentioned -
A bit confused I am. -
Always use the same format as in the AVI. Select PAL in this case.
Converting to avi keeping same screen size
By Dungogvolts in forum Video ConversionReplies: 18Last Post: 15th Apr 2012, 20:57 -
Does a DVD have to be compliant, as far as screen size?
By snafubaby in forum Authoring (DVD)Replies: 8Last Post: 24th Oct 2010, 23:18 -
Different screen size with different browsers
By disturbed1 in forum FeedbackReplies: 5Last Post: 27th Nov 2009, 05:10 -
16:9 Screen Size Question
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 10th Sep 2007, 18:43 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 11:16
