I've got a RCA RC5240P and I'm very happy with it BUT I want to UPGRADE to a PROGRESSIVE scan DVD player after XMAS. I'm looking for any suggestions on BRAND/MODELS to look at that have given good quality picture and play AS MANY formats as possible. I'd like to stay in the < $200 range if possible.....
THANKS FOR ALL REPLYS.
I have the Sony DVP-NS715P... Its a GREAT player loaded with cool features for around $199....
Geez, I sound like a Sony ad...
Merry Christmas. -
Hey guy, you can get the Pioneer DV-656A for <200.00 if you shop around.
Plays DVD-Audio too.... -
Cyber Home Progressive-Scan $69
http://www.bestbuy.com/detail.asp?&b=0&e=11177727&m=1&cat=32&scat=244
Philips Progressive-Scan DVD DVD724AT: $126
http://www.bestbuy.com/detail.asp?e=11101890&m=1&cat=32&scat=0
Samsung DVD-P421 Progressive Scan DVD Player: $149.99
http://www.compusa.com/products/product_info.asp?product_code=290418 -
I recommend the CP72.
The Panasonic RP82 is often recommended on the AVS forums by the videophiles because of the #1 rated progressive scan/3:2 pulldown chipset it uses. The Panasonic CP72 uses the same chipset, digital/analog converters, and mpeg decoder as the RP82, plus it has a 5 disc changer. There is also a $30 rebate on the CP72. And you can enable and disable the progressive mode remotely instead of having to use the button on the player. It also supports DVD Audio. I just got one, and no regrets. There have been reports of users using it with DVD-R/+R/-RW/+RW.
BD/DVD Interlace vs Progressive Scan: Which is better?
By Bonie81 in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2010, 06:01 -
Are there progressive scan DVD discs??
By seekt in forum DVD RippingReplies: 33Last Post: 21st Oct 2009, 12:52 -
Phlips DVP5982 Divx Player Progressive Scan issue
By imakshar in forum Newbie / General discussionsReplies: 9Last Post: 9th Jun 2007, 10:59 -
Pioneer dvd - dv 393 progressive scan locked in
By kbm in forum DVD RippingReplies: 7Last Post: 27th May 2007, 00:39 -
Creating DVD for progressive scan DVDplayer/TV
By halsboss in forum Authoring (DVD)Replies: 1Last Post: 18th May 2007, 19:58
