Strange problem appearing on 2 AVI files (only) I do have.These files play fine in WMP or DIVX, without sound synchro problem.
From Virtual Dub, I converted the audio to a wav file (as I always do). From TMPGEnc, I convert the files from AVI to MPEG (as I always do). When I then play the MPEG files, the sound is slightly out of synch.
Does anybody know what the issue could be?
I know TMPGEnc provides the ability to put an audio gap correction in ms, but 1. you have to know which value to enter. 2. As this does not happen in the original file, there might be an easier way to fix this.
Thanks a lot for your help! :P
Peegeelee
Results 1 to 1 of 1
How to fix audio synch problem in AVI file
By vertical in forum Newbie / General discussionsReplies: 153Last Post: 20th Aug 2021, 07:45 -
Changing sound synch
By SurreySpring in forum Video ConversionReplies: 1Last Post: 14th Nov 2011, 15:16 -
avi to mpeg -> no more sound
By myk in forum Video ConversionReplies: 22Last Post: 14th Mar 2008, 13:15 -
Virtualdub used with or without AviCutter=Sound Synch Problem
By johnharlin in forum EditingReplies: 11Last Post: 29th Dec 2007, 12:13 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 06:42
