I am developing a website and wanted to have an IRC chatroom similar to the VCDHelp one that you can access through the browser.
My question is does anyone know of a piece of software/script apart from jIRC that does this?
What I have set up is my own IRC room on Wondernet.
This you absoloutely NEED to do to get a web based one to work.
Then on my website I have a link to a java based client that people just need to put in their user details to connect to my room.
This is the link I use and is set up to connect to my fully functional and registered IRC channel but when you set up your own room if you look in the address you will see all the network / server and room name details and you can just change them to adapt to your room.....
Hope this helps......
(BTW....If you connect to my channel to test it then make sure you change from GUEST to your own nick.....Or one of the channel scripts may kick you out again......
http://www.mircx.com/cgi-bin/chat.cgi?BorderHsp=0&BorderVsp=0&cabbase=jirc_mss.bin&Cha...RealName=Guest -
Sorry about the big window but it's a really long address......
My other computer runs o.k. after my browsers finally load...
By tcory in forum ComputerReplies: 3Last Post: 2nd Jan 2011, 21:28 -
Different screen size with different browsers
By disturbed1 in forum FeedbackReplies: 5Last Post: 27th Nov 2009, 05:10 -
Do tabbed browsers use less memory than full browsers?
By yoda313 in forum ComputerReplies: 6Last Post: 18th Oct 2009, 18:30 -
Are there any updated browsers for WIN98?
By yoda313 in forum ComputerReplies: 5Last Post: 17th Oct 2008, 12:54 -
Site in different browsers
By DereX888 in forum FeedbackReplies: 9Last Post: 22nd Nov 2007, 14:03
