  1. the botton is not active and wont let me import menues..
  2. I suppose you've already looked here:
    http://www.ulead.com/learning/dws.htm
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
    Apr 2002
    Essex, England
    Make sure you press the 'play' button on the Finish section. This will stop teh motion menu preview from being greyed out - assuming that is the problem you are having? This is the only way of seeing the motion menu in preview, DVDWS brings up a window and renders the motion menu.
