Ok heres the setup..i have a AVI file that was downloaded that has video lockups about 5-10 times during the movie.
The video locks up on the frame but the sound continues forever...this can easily be fixed by simply clicking the status bar on the movie over and skipping afew seconds ahead of the frame and it moves ahead to the correct area and the audios synched fine.
My problem is i need to convert this to VCD, and cant do it with TMPGEnc because it locks up on these frames.
My question is..is there an easy way to just delete these frames from the movie? I know i could obviously go in and find the exact frame they lock up at and cut/rejoin around it..but that would take an entire days worth of work and frankly just isnt worth it.
Ive tried DivFix and it didnt fix any of the lockups...anybody?
Open in VirtualDub. Scan for bad frames (Video menu). It will run for a while and mask out any frames that are unreadable. Frameserve to tmpgenc.
Minor problem..when i run it through VirtualDub i get this error..
VirtualDub Error
Internal Error: MXX State left on: T:\projects\VirtualDub_old\main\VideoSource.cpp:11 01
Naturally this looks like something's wrong with the code at that line...
Also how would i go about frameserving? i was just introduced to this concept yesterday -
Are you running the latest version of VirtualDub? I think I saw the changelog said something about a bug fix related to that type of error.
For information on frameserving, see the guides under http://www.vcdhelp.com/convert, it looks like the one you probably want is http://www.vcdhelp.com/virtualdubframeserve.htm. -
Arsenic, this guide can help you out:
http://www.vcdhelp.com/forum/userguides/117930.php
Hope That Helps!!!:P
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 17:39 -
Bug in VirtualDub (?) -- can't cut desired number of frames
By ralf07 in forum Video ConversionReplies: 3Last Post: 21st Sep 2011, 17:50 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 15:00 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 03:39
