I am considering picking up either a PS2 or an Xbox. I want a console that allows me to make backups of my games easily. Which of these two are more compatible with home-burned games? I have children that can be downright brutal with media
If anyone here has had experience with backups for either system, please add your knowledge so that I may purchase the better system.
I know that PS2 requires a MOD chip to be installed to play backups (I have 2 dogs that can be downright brutal with media) unless you somehow have a "magic" PS2. Not sure about XBox.
Some PS2 games can be copied easily. XBOX games to copy them you have to hook up your XBOX to your PC then rip the files to the PC that way. They both require a mod chip to play copied games. I hope this helps some
Yea children brutal with media....right of course
PS2 needs a mod-chip
Games can be copied 1:1 with CDRWIN or Nero
X-Box needs a mod-chip
Games need to be downloaded or copied through a PC, built back up and may need protection taken off (not sure on that last part)
PS2 mod-chip needs soldering and it isn't easy
X-Box has a mod-chip you screw into the board, very easy. A red light says wasnt done right, a green light says yes.
www.ps2ownz.com
www.xbox-scene.com
Just alittle more info provided. -
Xbox games are fairly simple to backup.
Yes both systems require modchips to play them, I think PS2 has a no solder mod, and I know that Xbox does because I have one.
Either way to fully enjoy them make sure you have a dvd burner.
www.xbox-scene.com for Xbox info and tutorials. -
Yeah, pick xbox, it's great! I put a solder-free mod chip, and installed a 120GB HD. So I can copy games directly to HD and play from there, no need to ftp to PC. You can also instal media player and put avi/Divx/mpeg file either on HD/DVD/CDRW or stream from another PC and play it on XBOX. You will love it.
Backing up XBOX games
By HARRYSPADGE in forum ComputerReplies: 22Last Post: 16th Feb 2013, 19:27 -
How do I hook external audio up to my ps2/xbox 360?
By hellfire45 in forum Newbie / General discussionsReplies: 0Last Post: 11th Aug 2009, 23:37 -
backing up and playing through xbox 360 on my tv
By Dalspaugh in forum Authoring (Blu-ray)Replies: 1Last Post: 5th Nov 2008, 14:45 -
Is there an adapter to use your PS2 guitar on the xbox 360?
By yoda313 in forum Off topicReplies: 0Last Post: 18th Jul 2008, 20:28 -
Backing up my PS2 games....
By SE14man in forum ComputerReplies: 23Last Post: 16th Jan 2008, 11:12
