  1. Hey guys,
    I've got a broken Panasonic RV-31 on my hands. I'm almost positive that the laser is broken. Is there any place where I can find a replacement laser? Thanks in advance.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    all the info you need is on this page -- please read the "history of problems with panasonic players"
    service center details on the bottom ...
    http://www.hometheaterforum.com/bbs/archive/23342.html
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    Panasonic DVD Players ; The History Behind the Problem
    Contents
    Introduction
    Known Problems
    Layer Pause
    Chapter Skips
    Pixelation
    The 'NO DISC' Problem
    The 'LOCKED' Problem
    Sudare Noise/Venetian Blind Effect
    Other Down Conversion Artifacts
    Checking Your Firmware
    Current Firmware Numbers
    Getting Your DVD Player Repaired
    Reported Repairs
    Panasonic Customer Service and Consumer Affairs
    Panasonic Service Centers
    Panasonic Customer Care Plan (extended warranty)
    Home Theater Forum Owners Survey
    Contact Information
    Introduction
    Panasonic DVD player are some of the most popular DVD players that have been sold. Panasonic has several players on the market right now. The most popular models are the DVD-A120, DVD-A310, DVD-A110. Other models include the DVD-A100, DVD-A105, DVD-K510 and the Divx featured DVD-X410. All of the mentioned players may be affected, but this document will concentrate only on the first three players mentioned.
    Some of these players have exhibited problems that have been associated with design flaws by Panasonic. Not all players exhibit these problems. Some exhibit problems less frequently than others. There is no way to know exactly which player is affected and it’s up to each individual owner to determine if there is a problem, and to contact Panasonic if repairs are deemed necessary.
    One of the major issues with Panasonic DVD players is the failure of the optical pick up (laser) portion of the player. This is one of the most expensive part in the DVD player and the cost of replacing the part and the labor to do it, cost about as much as a new player. Most of the "hard failures" of Panasonic machines can be attributed to the failure of the optical unit. My data shows that there is no correlation between model number, manufacture date or firmware number and the failure of the optical pick up unit.
    One of the concerns is that the optical pick up unit is sensitive to heat. It is important to provide more that adequate ventilation to the DVD player and assure that heat generating components (amplifiers, receivers, etc.) are kept a safe distance from the DVD player.
    Other problems, chapter skips and some video artifacts can be attributed to variances in tolerances between the transport mechanism and optical pick up unit. These variances can cause some players to exhibit problems while other players do not. Some of the problems can be eliminated or reduced significantly by upgrading the firmware (ROM) in these players.
    From my research, I have concluded that Panasonic is aware of these problems, however, I do not know if they have fixed the manufacturing problems. Reports indicate that in 1998, most repairs consisted of replacing the optical pickup. Near the later part of 1998 and later, the repair approach was to replace the optical pickup or update the firmware or both. The new revision of firmware did not appear in new machines until March 1999. If your machine was manufactured after that date, then you have the new firmware, but there is no guaranty that the optical pick up will not fail.
    Panasonic is aware of these problems, but might not have the information readily available to their customer service representatives and service centers. If you want Panasonic to fix it, either for free or under warranty, it is best to be firm, but flexible. Unless its a hard failure, be prepared to foot the bill. Before you decide to pack up you DVD player and ship it off to a Panasonic Service Center, you must decide if your player really does have a problem and whether or not its worth it to get it fixed. Panasonic has a warranty of 90 days parts and labor, 1 year for parts (1 year parts for Canadian owners). If the warranty is expired you may have to pick up the cost yourself. There has been reports that Panasonic has picked up all charges, regardless of warranty, but that is the exception and not the rule.
    Known problems:
    The following are the most common problems regarding Panasonic DVD players. Again, let me stress that not all Panasonic DVD players exhibit these problems. Your DVD player my not need to be repaired or upgraded.
    Layer Pause:
    Panasonic players have been reported to pause at the layer change. On some discs it is quite obvious, and on other discs it has been quite seamless. It also seems to be a matter of personal preference and where the manufacturer’s decides where the layer switch occurs. A layer pause seems to be noticeable on all DVD machines, Panasonic included. Some players are better than others. Some times it depends on the disc and that will vary disc to disc, too.
    There seems to be a consensus, among all DVD player owners, that a pause is inevitable and is the price we pay for this new technology. In regards to Panasonic, customers have reported that the firmware update seemed to improve the speed at which the layer change occurs, although may not eliminate it in all instances.
    Chapter Skips:
    Players effected: Mostly Panasonic DVD-A110, and DVD-A310.
    Description: The problem occurs on some dual layer (RSDL) disc. At the layer change, the player will skip the next chapter (skips the first chapter on the second layer), and continues on the following chapter. Some people have reported that replacing the optical pickup unit solves this problem, however, most just need the ROM updated, in some cases both were replaced.
    Panasonic owners have also reported that their player "locks up" at the layer change.
    Not all players and discs will exhibit chapter skipping. A good majority of older players with the original firmware have no problems what so ever. Some of the most common disc that have been reported to skip on Panasonic DVD players are listed below.
    Pleasantville Armageddon
    The Blues Brothers ; Collector;s Edition The Man In The Iron Mask Chapter 27
    A Bug;s Life Mountains of the Moon
    The Ten Commandments (2nd disc, chapter 33) The Mask Of Zorro
    Godzilla Clear And Present Danger
    The Rainmaker Vertigo
    Silence of the Lambs The Good, the Bad and the Ugly
    The Great Escape The Dirty Dozen
    Animal House CE You;ve Got Mail
    Pixelation/Drop Outs:
    The loss of data is exhibited by small squares being displayed or lost frames or dropped or broken audio. There can be a wide variety of reasons that this occurs and is not isolated to Panasonic machines. A good majority of pixellation is caused by dirt, dust or scratches on the disc. In some cases the poor mastering or encoding of the disc can cause problems. These "problem discs" are well documented and do not necessarily mean that your player needs upgrading or repairs.
    If your player exhibits excessive pixellation on several discs, especially ones that have played flawless before, the optical pickup may be failing. There have been several reports that this problem has not shown up until several weeks to several months after the purchase, and progressively has gotten worse until complete failure of the unit. Below is some of the discs that owners have reported pixellation that was not related to dirty, scratched or other reasonable explanations:
    The Saint Hair
    Mask of Zorro Armageddon - Criterion
    Mountains of the Moon Pleasantville
    The English Patient Tomorrow Never Dies - Special Edition
    You’ve Got Mail Boogie Nights
    Usual Suspects Antz
    The ‘NO DISC’ problem
    Description: A disc has been loaded into the tray and the machine can’t read it. On the display reads the error ‘NO DISC’. Opening the tray and then closing it sometimes work to clear this error. Alternatively, if all DVDs (and possibly CDs) cannot be recognized in the player, the optical pickup unit has probably failed. This is a hard failure and is covered by Panasonic warranty. If the warranty has expired, then good luck.
    Found on a newsgroup on the ‘NO DISC’ problem:
    "Remove the player’s cover and locate the disc transport unit. Find the small, rectangular, white connector with the (usually) gray wire coming off it that leads the main board in the unit. Make sure that it is connected tightly at the disc transport end. Take it off, push it back on, etc. This has fixed the problem for many who have experienced it."
    The ‘LOCKED’ Problem
    Player locks up, displayed ‘LOCKED’. Pressing STOP on the unit and POWER on the remote locks and unlocks the tray. Turning power off/on or unplugging the machine may unlock it.
    Sudare Noise/Venetian Blind effect
    Players affected: Panasonic DVD-A105, DVD-A110, and DVD-A310, some DVD-A120s manufactured before March 1999.
    You probably have already seen it, but you probably didn't know that is what it's called. "Sudare noise" is what Panasonic engineers call the playback artifact that is known as the "levelor effect", "blind effect", etc., etc. The "problem discs" that have well known problem have been "The Saint" and "The Man In The Iron Mask. Other titles that exhibit artifacts are "Tomorrow Never Dies" from MGM, "Heart & Souls" from Universal, and "Krakatoa East of Jave" from Simitar, and the opening scene of "Boogie Nights".
    Sudare noise is, in fact, a player defect, and not an artifact inherent in the player's MPEG decoder design. It can be fixed by updating the firmware in the player. Also, this firmware upgrade also addresses the "chapter skip at layer change" problem. According to my information, the fix is really rather easy. Panasonic isn't going to call you at home and offer to fix your player. They are not going to recall the players. If you want your player fixed you will have to call Panasonic's customer support number (1-800-211-PANA) or the nearest service center and tell them about the problem and insist they correct it without cost to you (expect to pay one-way shipping, however). There may be some cases where you will meet resistance. If you simply can't get them to agree, then pay for it yourself. It will be a lot cheaper than a new player and it will correct the only real flaw in the best DVD player in it's class.
    Other Down Conversion Artifacts:
    These artifacts include the ‘moiré’ effect, horizontal lines in picture, softness or sharpness in 16x9 down converted titles. This problems seems to be inherent in all Panasonic players and may be just a fact of life until the technology improves or Panasonic changes the design. I don’t think a firmware upgrade will improve this, however there has been some subjective reports that these problems are improved with the new firmware.
    Checking your firmware number:
    To check the firmware number, press and hold the "pause" and "open/close" on the front of the player, with the remote in your other hand, press the #7 on the remote. On the front panel display, there will be an eight or nine digit/lettered number.
    Unless you have sent your DVD-A105, DVD-A110, DVD-A310 in to Panasonic for the firmware upgrade, you have the original firmware version. These players will be subject to the Sudare Noise artifact and the occasional chapter skipping at layer transitions. However, this does not mean that your player needs to be sent in. Many people have reported that their player hasn't had any objectionable problems. Sudare Noise will occur on all of these players, but the actual number of discs, that have the MPEG encoding error that triggers these artifacts, is relatively small. If you are happy with your player's performance, don't sweat it, enjoy the player.
    There is a problem with some of the early model DVD-A120s (manufactured before March 1999) that where shipped with the old revision of firmware. Panasonic claims that only 4% of DVD-A120 players that were shipped, are affected. If one has a player that exhibits severe pixellation on some dual layer discs or skips chapters, this is likely one of the affected players. The "fix" is a simply upgrade of the firmware in the onboard ROM.
    Current firmware numbers:
    The following firmware numbers are known to be the most current revision. All DVD-A120s should have this number (or similar) if manufactured March 1999 or later. All other players will have these numbers (or similar) AFTER the upgrade.
    DVD A120 - 0100404C4, 0100453C8
    (However, several owners with an original firmware number of 0100367C2 have reported little or no problems)
    DVD A310 - **** U733, after upgrade, the U733 is the important part.
    DVD A110 - **** U733, after upgrade, the U733 is the important part.
    Getting your DVD player repaired
    If you determine that you want or need to have your Panasonic DVD player repaired. Your best bet is to contact the Panasonic Service Center nearest to you. The warranty is for 90 days parts and labor, 1 year parts. They are (or should be) aware of the problems. Many people have reported that calling the main Panasonic Customer Service is a waste of time. Some people who have dealt directly with the service centers report faster service, and on occasion, Panasonic has waived the labor charge. Your mileage may vary.
    For those of you who insist that Panasonic should responsible for all repairs because they sold faulty machines, remember that this a random problem, it only affects some players and certain discs. DVD is new technology and we, as first adopters, also should bear some of the burden. I hope that Panasonic did not intentionally sell faulty machines. Looking at the cost of the labor and parts to repair the DVD player, it totals almost as much as a new machine. You should be happy for what ever you can get. Most of the hard failures will be paid under warranty and that will cost Panasonic. They will learn from this, believe me.
    Reported repairs:
    The most common repair has been the replacement of the "Optical Pick-Up Unit" and the usually the firmware, too (also called ‘flash memory’ or ROM). If the only problem is with MPEG artifacts and chapter skips, a firmware upgrade usually does the trick. There has also been several reports of a capacitor change.
    Panasonic Part Number Description Price
    VED0378 Optical Pickup Unit $152.35
    TOTX178 Optical Signal Modifier $9.04
    ? Capacitor ?
    Home Theater Forum Survey - Firmware numbers and owner reported problems:
    np = no problem
    px = pixellation
    lu = lock up
    ld = ‘LOCKED’
    cs = chapter skip
    nd = ‘NO DISC’
    DVD-A120
    Member
    Firmware #
    Manufacture Date
    Problem/repair
    Danny Bonnel
    0100367C2
    April 99
    np
    Craig MM
    0100367C2
    np
    M. Armanini
    0100367C2
    Jan 1999
    minor px, lu
    Randy M
    February 1999
    px, lu
    Randy M (2)
    0100404C4
    March 1999
    np
    Kameljeet
    Feb 1999
    px, cs
    Ruhrie
    px
    tony tran
    0100404C4
    March 1999
    np
    Robert Monzo
    0100367C2
    Feb 1999
    np
    David Ogburn
    0100367C2
    Feb 1999
    np, minor px
    Peter Yang
    0100367C2
    0100453C8
    Feb 1999
    px, lu,
    repaired
    andrew
    np
    Andrew Grall
    np
    Steve Dawson
    0100367C2
    np
    Dick Smyrak
    0100389C3
    Feb 1999
    Returned dead
    Dick Smyrak (2)
    0100404C4
    Feb 1999
    np
    thermalcvd
    0100389C3
    Feb 1999
    np
    Brian Brenner
    0100389C3
    np
    Jay H
    0100367C2
    Feb 99
    Np, minor px
    Alec Karys
    nd
    Mark Maruska
    0100367C2
    DVD-A310 (The U604 indicates first version of firmware.)
    Member
    Firmware #
    Manufacture Date
    Problem/repair
    Sam T.
    0107 U604
    LARUE
    0107 U604
    ArjE
    0107 U604
    March 1998
    Tom S
    0108 U693
    October 1998
    cs
    John Morris
    June 1998
    cs
    Mike Tyson
    nd
    S. Yarbrough
    0107 U659
    pre October 1998
    px, lu, repaired
    Aaron Sharpe
    pre Dec 1998
    px, lu, nd
    Thomas D
    0108 U693
    pre Nov 1998
    nd, repaired
    Randy Brist
    px, lu, returned
    James Dubinsky
    optic, firmware
    George Fievet
    pre July 1998
    np
    Rob Behm
    pre Dec 1998
    np
    Jack
    pre Dec 1998
    np
    Vern Sharp
    pre Dec 1998
    px, cs, repaired
    B. Williamson
    April 1998
    px
    Paul Kunze
    cs
    Pete Fitzgerald
    pre Jan 1999
    np, minor px
    Dano Garcia
    March 1998
    cs, repaired
    Chris Berban
    March 1998
    px, lu, repaired twice
    Wade
    0107 U604
    March 1998
    cs
    Annie Ruisi
    Oct. 1998
    dead, in repair
    Fabian Fata
    np
    Wolf Jenkins
    0107 U604
    March 1998
    cs, minor px
    Chance
    0107 U604
    March 1998
    cs
    C. Sonntag
    np
    sam t
    nd
    Mark Lee
    pre 1998
    optic failure
    MaxY
    np other than sudare
    Alex Yang
    np
    B Lennon-Jones
    0108 U733
    Nov 1998
    optic, firmware upgrade
    DVD-A110
    Member
    Firmware #
    Manufacture Date
    Problem/repair
    M Armanin
    0107U733
    Pre April 1998
    nd, px, repaired, firmware
    Bill (netcom)
    px, lu, repaired
    Keith (cv.hp)
    px, lu
    Martin Belair
    0108 U659
    June 1998
    cs
    Kwasi Chan
    0107 U733
    April 1998
    px, lu, repaired, update firmware
    Rfallstich
    0107 U604
    March 1998
    np
    Erwin
    October 1998
    np
    Jan Strnad
    June 1998
    np
    Brain Leslie
    0108 U733
    July 98
    cs, updated firmware, optics
    Jeff Sy
    nd, px, updated firmware, optics
    John Petitjean
    nd, lu
    AaronJB
    np
    Chris Beveridge
    pre June 1998
    np
    Dave Frattaroli
    pre May 1998
    px, nd, optic
    Phil L
    px, cs
    David R
    0107 U604
    March 1998
    np
    G Robertson
    October 1998
    nd, px, dead
    mrowly
    0107 U604
    March 1998
    np
    Phil Reed
    0108 U667
    July 1998
    np, minor px
    Chris Maynard
    dead in 6 months
    M. Fennessy
    pre Dec 98
    np
    Paul Simoneau
    np, minor px
    D Pagoulatous
    Oct. 98
    np, minor cs, minor px
    John Williams
    cs
    Robert Monzo
    June 1998
    cs, minor px, updated firmware
    Bobby Sackman
    pre April 1998
    np
    Jerry Gracia
    0108 U693
    Aug 1998
    cs, nd, px
    D Shenoy
    pre April 1998
    np
    Abem
    0108 U667
    July 1998
    cs
    Martin B
    June 1998
    minor px
    Dave Phipps
    August 1998
    cs
    Steve Anderson
    June 1998
    lu
    Rob Burnard
    0107 U659
    June 1998
    np
    M Quist
    Oct 1998
    np
    David J
    0108 U693
    Sept 1998
    np
    EdC
    0108 U693
    Aug 1998
    np
    Derrick
    pre June 1998
    np
    josecruz
    0108 U604
    April 1998
    cs, lu
    Paul E. Fox, II
    0108 U733
    pre Sept. 1998
    Leo Kerr
    0108 U604
    April 1998
    np
    Tim Winders
    0107 U733
    May 1998
    cs, px, updated firmware
    Brian Price
    March 1998
    np
    Matt Kasprzak
    0108 U693
    Nov 1998
    np
    Johnson
    np other than sudare noise
    Scott A. Pope
    np
    T. Alexander
    pre Dec 98
    np
    Randy Talbot
    np
    Hal Masonberg
    minor px
    Brain Knolhoff
    cs
    Bill Fog
    three failures (optic?)
    RustyR
    cs
    John_F
    nd
    James Rogers
    cs
    Jeff Brown
    cap, optic
    DrewC
    0108 U733
    Pre Dec 1998
    Px, firmware
    Dwight Amato
    np
    Eric Howell
    0108_u693
    Px, lu
    Ross Bartrick
    0107 U604
    March 1998
    minor px
    Steve Black
    For Product information, operating assistance, literature requests, dealer location and all customer service inquiries please contact:
    1-800-211-PANA (7262)
    Monday-Friday 9 am – 9 pm
    Saturday ; Sunday, 9 am – 7 pm
    Eastern Standard Time.
    Panasonic Consumer Affairs
    One Panasonic Way, 2F-3
    Secaucus, NJ 07094
    Buy that extended warranty through Panasonic and make them pay for it. Reports have said that it is expensive, around $125. Whether or not it's worth it, is debatable. In general, extended warranties are not worth it, but you may feel differently.
    The customer repair plan offers all of these benefits:
    Labor to complete repairs
    Replacement parts
    Electronic or mechanical adjustments
    Specified internal cleaning
    Requested preventative adjustments
    No hidden charges or deductibles. Complete coverage for one low, up front price.
    Coverage is transferable
    CALL 1-800-637-2007
    Certain restrictions apply Offer only valid in the United States with the exception of Florida. Applications for coverage are subject to the final acceptance by our company
    OFFERED AND ADMINISTERED BY:
    Customer Care Plan Administration
    PANASONIC SERVICES COMPANY
    544 Tolgate Road, Suite C
    Elgin, IL 60123-9964
    Panasonic Service Centers:
    CALIFORNIA
    6550 Katella Avenue
    Cypress, CA 90630
    (714) 373-7430
    800 Dubuque Avenue
    So. San Fransisco, CA 94080
    (650) 871-1397
    20201 Sherman Way, Suite 102
    Canoga Park, CA 91306
    (816) 709-5345
    3878 Ruffin Road, Suite A
    San Diego, CA 92123
    (619) 560-9205
    COLORADO
    1640 South Abilene St., Suite D
    Aurora, CO 80012
    (303) 745-8613 FLORIDA
    3700 North 29th Avenue, Suite 102
    Hollywood, FL 33020
    (954) 920-2329 GEORGIA
    8655 Roswell Road, Suite 100
    Atlanta, GA 30350
    (770) 650-8540
    ILLINOIS
    9060 Golf Road
    Niles, IL 60714
    (847) 299-1914 1703 North Randall Road
    Elgin, IL 60123
    (Pick-up/Drop-off only)
    (847) 299-1914
    MARYLAND 62 Mountain Road
    Glen Burnie, MD 21060
    (410) 760-3545 MASSACHUSETS
    60 Glacier Drive, Suite G
    Westwood, MA 02090
    (781) 329-4281 MICHIGAN
    37048 Van Dyke Avenue
    Sterling Heights, MI 48312
    (810) 939-2883
    MINNESOTA
    7850-12th Avenue South
    Airport Business Center
    Bloomington, MN 55425
    (612) 854-7007 OHIO
    2236 Waycross Road
    Civic Center Plaza
    Forest Park, OH 45240
    (513) 851-4700
    PENNSYLVANIA
    2221 Cabot Blvd. West, Suite B
    Langhorne, PA 19047
    (215) 741-0904 Chartiers Valley Shopping Center
    1025 Washington Pike
    Bridgeville, PA 15017
    (412) 220-8065 TENNESSEE
    3800 Ezell Road, Suite 806
    Nashville, TN 37211
    (615) 832-5950
    TEXAS
    7482 Harwin Drive
    Houston, TX 77036
    (713) 781-2509
    13615 Welch Road, Suite 101
    Farmers Branch, TX 75244
    (972) 385-1976 WASHINGTON
    20425 84th Avenue South
    Kent, WA 98032
    (253) 395-1778
    HAWAII
    99-859 Iwaiwa Street
    Aiea, Hawaii 96701
    Phone (808) 488-1996
    Fax (808) 486-4369
    PUERTO RICO
    Matsushita Electric of Puerto Rico, Inc.
    Panasonic Sales Company/Factory Service Center:
    Ave. 65 de Infanteria, Km. 9.5
    San Gabriel Industrial Park
    Carolina, Puerto Rico 00985
    Phone (787) 750-4300
    Fax (787) 768-2910
