By the way as far as compatibility goes, on standalone dvd players for VCD is there any compatibility differences between ntsc and ntsc film? or will the players over here in the US play both. A few players I am looking at getting say VCD as a format they play. Does this usually mean ntsc, film or both?
Since most DVD's made from movies are 24 fps NTSC film, any player that can do VCD should be able to do both.
That doesn't follow. Since most DVD's use AC3 for audio, you can use that for VCDs too? (no you can't, BTW).
In the perfect world, NTSC-FILM should be as supported as NTSC in all VCD compatible players. In the real world, there are some players that can't play FILM framerate VCDs properly.
Regards.Michael Tam
w: Morsels of Evidence
Using NTSC (16:9) and PAL (4:3) sources to restore a film...
By takearushfan in forum RestorationReplies: 61Last Post: 3rd Mar 2012, 15:13 -
NTSC/PAL but exact film length: How so?
By Anonymous5394 in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2010, 11:42 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
Question regarding NTSC Film DVD
By txporter in forum Video ConversionReplies: 14Last Post: 30th Nov 2009, 09:29 -
FPS NTSC & PAL Film/Digital
By flamingo in forum Newbie / General discussionsReplies: 5Last Post: 13th Nov 2007, 13:21
