I stripped down a movie(extra audio/subtitles). This is movie only. After stripping down, the VIDEO_TS folder was 4.83gigs. I used VOBedit and demuxed all video. Now in this folder is the normal VTS_01_x.vob files and the new VTS_01_1.m2v file. The .m2v is 3.99 gigs. So is this the new video file for the movie? What do i do with this .m2v file? Little confused
you should have a ac3 file also. then m2v file is video only. you said its only 3.99 gigs so that plus audio should be under 4.7. so if i was you i would download ifoedit and author those two files into dvd files and then burn them with nero of what ever program u have that can burn dvd files.
Actually, if that 3.99 GB measure is from Win Explorer, that is a base2 number. The 4.7 GB of a DVD-R is a base10 number - converted to Base2 GB's is only 4.38 so you would only have 0.39 GB of space left for audio.
But anyway, a 90 minute film with 224kbit audio will only require about 150 MB for audio so you should be safe.
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 06:17 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
How to reverse a M2V file
By lorix in forum EditingReplies: 2Last Post: 13th Nov 2008, 04:09 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08 -
extracting audio from m2v file
By matneaves in forum AudioReplies: 1Last Post: 30th May 2007, 16:56
