which is the better way when converting to svcd to just convert to one big file and then cut them in half or to just convert half by half using source range im trying to make sure that the audio stays in sync thanks for any help
I think source range better. Most of the time cutting with bbmpeg works fine too, but source range always works and you can pick the exact frames where you want the pieces to start and end.
i only use bbmpg for vbr svcd's because if you want the max bitrate per disc source range is just trial and error. no guess work with bbmpg. but for cbr definetly source range.
Originally Posted by Compound
AVI Cut
By JP in forum EditingReplies: 4Last Post: 6th Mar 2012, 19:12 -
Final Cut X
By Tom in HD in forum MacReplies: 1Last Post: 29th Oct 2011, 09:35 -
How I can cut TS files ?
By Torresinho in forum EditingReplies: 1Last Post: 14th Feb 2010, 15:15 -
how to cut....
By marlo in forum Newbie / General discussionsReplies: 3Last Post: 27th Jan 2008, 02:28 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05
