I am trying to convert a DVD to VCD and want to use TMPGEnc for encoding (the only encoder I trust for quality). So I set up Flask and AVISynth plug in. Chose output to "Link to AVISynth', started frameserver. And then in TMPGEnc tried to open the avs file and got error message "IPCSource:Wrong Server Version"
Anyone has any idea what's goin' on ?
I'm using Flask 0.594, TMPGEnc 12i. Can't say which version the AVISynth is.
I wanna bust Blockbuster
OK folks, don't bother replying this one. I found the solution. I was using AVISynth and AVISynth plugin of different version. Downloaded latest versions of both and I'm in business. Found one problem though. The Flask frameserver continues serving blank frame even after the video clip is finished and TMPGEnc continues to encode those blank frames. So I have to manually stop the process. Anyone has any idea why ?
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
720p 59.94 to 480p 23.976 in TMPGEnc w/o Using AVISynth
By CubDukat in forum Video ConversionReplies: 6Last Post: 19th Oct 2009, 09:51 -
Audio Problem using AVISynth and TMPGEnc Xpress
By 1980sumthin in forum Video ConversionReplies: 10Last Post: 27th Jan 2009, 05:27 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07 -
Avisynth/TMPGEnc Xpress Audio Sync Issue
By Borflex in forum Video ConversionReplies: 4Last Post: 2nd Jun 2007, 14:10
