Hi me again.
I am getting the green screen in powerdvd 4.0 playing a svcd
For some reason this problem doesn't arise when a cd is played where I turned off the "joliet" option.
In windows 98 I never had this problem.
These are the things the configuration during play displays, they are quite different.
From ("joliet")cd:
From the hard disk:Player Information :
Current Focus Drive : D:
Display Information :
Display Mode : DirectDraw
FourCC Code : YUY2
Surface Type : Overlay
Video Attribute :
Video compression mode : MPEG-2
Source picture resolution : 352x480 (525/60)
Frame Rate : 29.97
Bitrate : 2.53Mbps
Audio Attribute :
Audio Coding mode : MPEG-1
Sampling Rate : 44.1kHz
Number of Audio channels : 2
Bitrate : 192 Kbps
Hardware Information :
Processor: AMD Athlon(tm) Processor running at 1410 MHz
3DNow! Technology : In Use
Enhanced 3DNow! Technology : In Use
3DNow! Professional Technology : Not Detected
IA MMX Technology : In Use
IA Streaming SIMD Extensions : Not Detected
IA SSE 2 : Not Detected
Video Accelerator : NVIDIA Hardware Video Acceleration (not in use)
Multispeakers Audio Device : Not Detected
for one "Video Mode : Weave" is not in the info when played from cdPlayer Information :
Player Region Code : Not Specified
Title Region Code : Not Available
Video Mode : Weave
FourCC Code : YUY2
Video Attribute :
TV system : 525/60 (NTSC)
Aspect Ratio : 4:3
Display Mode : reserved
Source picture resolution : 480x480
Frame Rate : 29.97
Source picture letterboxed : Not letterboxed
Bitrate : 2.53Mbps
Audio Attribute :
Audio Coding mode : MPEG-1 or MPEG-2 without extension bitstream
Sampling Rate : reserved = 2
Audio application mode : Not specified
Bitrate : 192 Kbps
Number of Audio streams : 1
Subpicture Attribute : Not Available
Processor: AMD Athlon(tm) Processor running at 1409 MHz
SPDIF Output Device : Creative ES1373 (not in use)
maybe that is the problem?
Thanks for any help
Ro
Results 1 to 1 of 1
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 01:06 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 20:00 -
What is wrong with this picture? Zoom? Overscan? Crop?
By Xenogear900 in forum Newbie / General discussionsReplies: 9Last Post: 9th Sep 2008, 16:35 -
Video has sound but no picture from encoded avi file. What's wrong?
By Ivor Bigone in forum Video ConversionReplies: 4Last Post: 30th Jun 2008, 10:01 -
By anonjon in forum RestorationReplies: 20Last Post: 10th Sep 2007, 13:02
