  1. hey all,
    just wondering if theres any way to make the movie play without the main menu (so i can save space on the dvdr, as theres no special features i need to access). If so what program(s) would i need and which files would i still need to copy over? here are the files i have at the moment (its spiderman):
    video_ts.bup
    video_ts.ifo
    video_ts.vob
    vts_01_0.bup
    vts_01_0.ifo
    vts_01_0.vob
    vts_01_1.vob
    vts_01_2.vob
    vts_01_3.vob
    vts_01_4.vob
    vts_01_5.vob
    some1 has probably asked this before on this forum, but i cant find the solution so any help on this would be gretaly appreciated
    Thanx,
    Bob
  2. Member wulf109's Avatar
    Jul 2002
    If you author with Ifoedit it will auto run in any DVD player. If you author with SpruceUp just make it your first play and it will auto-run.
  3. Here is your Exact answer:
    Delete:
    video_ts.bup
    video_ts.ifo
    video_ts.vob
    vts_01_0.bup
    vts_01_0.ifo
    vts_01_0.vob
    Run IFOedit:
    Create IFO's
    Load in VTS_01_1.VOB
    Save, Wait while IFOedit scans all your VOBS
    Now IFOedit will write NEW
    video_ts.bup
    video_ts.ifo
    video_ts.vob
    vts_01_0.bup
    vts_01_0.ifo
    vts_01_0.vob
    Close IFOedit
    Run IFOedit
    Load up the VTS_01_0.IFO
    GET VTS Sectors, press OK....
    DONE!
    Thats the exact steps to make it work, Good Luck
    VidHack
    Feb 2001
    Macondo, Puerto Rico
    Hi VidHack,
    I ran the process and I am still missing the video_ts.vob and vts_01_0.vob files. Any idea?
    Regards,
    Jose
  5. Just create dvd and copy the files yoru left with over. vidhack woz right with the instructions and it works fine, just burn the files that you have to dvd-r now
  6. Go to www.doom9.org and there is perfect guide for ehat you need.
    Feb 2001
    Hi ClockWork,
    I am testing the movie using WinDVD and CinePLayer without any luck.
    Will my dvd player play the movie without the missing files?
    Regards,
    Jose
