    Oct 2002
    Australia
    I just downloaded Die another Day and when I play the .avi file there is just sound, when i tell it to show video it just has a screen thats black!!!!!!
    Help please!
  2. i would guess that you dont have the correct codec required to play this file. its going to be divx of some sort.
    may i suggest getting a program called "Gspot" from here:
    http://www.headbands.com/gspot/
    run the program and locate your avi file.
    it will tell you what codec the file uses. then its up to you to get them and install them. you should be able to get all you need from the tools section of this site.
