    Oct 2002
    Huntsville, Ontario, Cana
    Is it possible to have an Introductory clip in a SVCD?
    By that I mean a short clip that plays as soon as the SVCD is installed?
    It would finish and then the main menu would appear.
    Willy
    Will
  2. I have heard that in TSCV you can add an intro mpeg to your vcd/svcd before the menu. I have never used the prog so I dunno exactly how it works. Hope this helps ya.
  3. winOnCD lets you add a intro
    Oct 2002
    WinOnCD? Never heard of it before....
    What is it and where would I get it?
    Will
  5. vcdeasy is freeware and works well.
    Panasonic DMR-ES45VS, keep those discs a burnin'
