i have a series of vcds on my hardrive that i captured from various means and converted to vcd using tmpgenc. i burned those to cd and watched them and i liked it.
i now have a large set of vcds and now that i am learned (somewhat) in the art of editing i, i got the idea of getting these into some semblance of order. i wish to edit the clips , join, transition, title and author to a cd to compile a collection .
no editing programs i own will edit the vcd footage! premiere wont play the video and frequently crashes! moviemaker also will not edit the vcd files either, and my best hope was ulead videostudio- to no avail. just adding a title in videostudio will send it out of sync!!
am i stuck with just what i got? converting these to an avi would only worsen the image, true?
you can cut, trim, snip, join mpeg1/2 files with M2Edit. Good luck with adding transitions, titles and the like... I donlt know any programs that will do that with mpeg files.
come to think of it I think someone mentioned to me that the new Premiere can now accept mpeg files as input, don't take my word for it but look into it.
capturing dvd compliant mpeg-2 with vdub
By wolfdogg in forum Capturing and VCRReplies: 0Last Post: 10th Jan 2012, 19:06 -
need to join 2 dvd compliant mpeg files (having identival characteristics)
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 20th Oct 2008, 10:37 -
Anyway to make a non compliant disc compliant?
By zanos in forum Authoring (DVD)Replies: 9Last Post: 23rd Feb 2008, 10:46 -
Video corruption when trying to convert MPEG-2 to DVD-compliant
By DB83 in forum Video ConversionReplies: 2Last Post: 31st Jan 2008, 19:00 -
No audio in dvd compliant mpeg 2 files
By Bertieboo in forum Video ConversionReplies: 6Last Post: 14th Nov 2007, 15:35
