hi i am a newbie to the world of video etc ... can anyone help with suggestions on how i can get vcd recordings where the sound/synch is not out of balance ??? i notice when capturing the video the picture and sound are not smooth and stable but when i play back the recording/capture the picture is fine but the soundtrack is not lined up correctly . i am using a 600 mhz pentium 3 + 128 ram ... i had a brief look at tmg but it looks too techy ... desperate ..
emohara50@hotmail.com
"Today is only yesterdays tomorrow"
Emohara,
1. What are you using to capture your video(Software and Hardware) ?
2. Do you compress the caputured movie directly to mpeg 1 with your caputer card or convert it later with other sofware ? -
hi and thanks for your reply
1 - i am using a pinnacle pctv pro
2 - the few attempts i have made to record captured short video pieces to vcd i have used nero for ther job , i have downloaded a tmpgenc but i am sure i will find using that very difficult without further instructions and guides . any other suggestions would be most appreciated .
cheers eric
Transferring Sky+ recordings to PC
By grandsire02 in forum Newbie / General discussionsReplies: 3Last Post: 21st Nov 2010, 16:37 -
8mm recordings visible only when FF
By ophi in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 29th Jun 2010, 21:37 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 13th Jan 2008, 00:47 -
Help getting recordings off HD DVR onto DVD in 16:9 – not 4:3 - Please!
By ChrisU2Edge in forum DVB / IPTVReplies: 3Last Post: 12th Jul 2007, 21:43 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 06:42
