I wonder if someone "out there" knows some links to pages where i can download subtitles?
I also wonder where and if i can download firmware updates for my philips dvd player?
Originally Posted by Wild Punk
http://www.divxsubtitles.net/index.php
http://www.subtitles.cz/en/default.asp?show=LOGIN&err=NL
http://divxstation.com/comm/topic.asp?page=2&i=4
http://www.divxsubs.com/
http://dvd.box.sk -
Originally Posted by Kban
http://divxstation.com/softwareId.asp?sId=178 -
Another question, I went to a one of those links and downloaded a zip file that contained .txt files with the subs inside, something like this (guess what movie)
{69394}{69482}Buen Sméagol así lo hace, Amo lo dijo.
{69482}{69513}Eso hice.
{69719}{69754}¿Y ahora qué?
{69805}{69846}No podemos cruzarla.
{70912}{70932}Mira.
{70954}{70972}La puerta.
{70990}{71015}Se está abriendo.
{71198}{71231}Puedo ver un camino para bajar.
{71264}{71292}- ¡Sam!| - ¡No!
{71365}{71394}¡Amo!
{73414}{73473}- No te pido que vengas conmigo, Sam.|- Lo sé, Sr. Frodo.
{73515}{73589}Dudo que éstas capas élficas,| nos oculten allí adentro.
Now what do I do with these text files? I thought subs were supposed to come in a different format. -
If you are just going to watch the movie in the computer then you can install this program,the only thing you need to do is to rename your subtitle like your movie example if your movie is "Blade 2" then rename your sub to "Blade 2" too and put the subtitle in same directory as the movie.
http://vobsub.edensrising.com/vobsub.php
If you want a different format of the sub then you will find a tool called Subresync in the program above which you can easy change your subtitle format. -
Here are a link with a lot of subtitles links:
http://www.divx-digest.com/subtitles/index.html
Lost links
By G-smashed in forum EditingReplies: 0Last Post: 11th Aug 2011, 19:24 -
Forum links all messed up
By lordsmurf in forum FeedbackReplies: 4Last Post: 7th Aug 2010, 16:15 -
Only to gather a few links in the one place.
By pcspeak in forum TestReplies: 0Last Post: 24th Dec 2008, 16:35 -
Mouse and links
By Jomapil in forum ComputerReplies: 4Last Post: 2nd Nov 2008, 19:07 -
mIRC Links in Firefox
By Xenogear900 in forum ComputerReplies: 1Last Post: 15th May 2007, 11:52
