First off let me say this a great site and thanks.....I've used it alot to solve my problems....
this has probably been asked before......but I didn't find any problems like this when I searched the data files......
I down load movies from the net,, and recently bought this computer...hp 2.66gh windows home xp.....
I can not get some of the files to open with this computer....I've down load all the divx codes(3.11,4,5.02 and the nimo code pack) and also reset the priority from -2 to 2 on the direct show multimedia in tmpg(same thing here)...........
they down load alright and when I try to open them I usually get a black screen or a black screen with green in it......
this only seems to happen with the divx code 5 movies.....
can anybody tell me what I have forgotten to do or what I'm doing wrong.......
Thanks for any help...............
Allen
Maybe you should try installing the Xvid Codec. Some AVIs are compressed with it, and if you don't have it you usually get a green picture.
There are only 10 types of people in the world:
Those who understand binary
and those who don't. -
i dont know if this is the solution to your problem, but i had troubles when i first installed divx5 on my system. it stopped playing divx3 files properly.
i found the following in a thread at doom9:
This is a fix to the divx3fix.reg originally posted to the doom9.org forum.
It allowed you to install divx 5 and continue playing divx 3.11 with the original codec. You can check this with the sample divx 4.12 video, since the divx 5 codec also has the glitch.
The problem was that with the fix, AntiFreeze stopped working, so this new fix changes the priority of 80 to 85 in both the divx 3.11 and AntiFreeze registry. Also works in Win98 now, as well as Win2k and WinXP.
Make sure divx 3.11, divx 5, and AntiFreeze (DivxAF) is installed, before doubleclicking on the .reg files.
http://www2.hawaii.edu/~rnakahar/Divx_3-5-AF_fix.zip
For your info the whole thread is located here: http://forum.doom9.org/showthread.php?s=&threadid=19404&perpage=20&pagenumber=1 -
Thanks Wolleric and Divz.....tryed both suggestions with no help......
also noticed on the movies that want open(or maybe a better word would be start).....trying to open in virtualdub.....get this massage....uncompressed RGB1......whats that mean..never heard of RGB1 format......also see on some the message.....format DX50......
anybody know what these mean?????
thanks
Allen -
Try ffdshow (you should be able to get to the download page by a simple serach on the net)
Try uninstalling the Nimo Codec pack...and just put on the DivX and Xvid codecs
http://www.divx.com/divx/
and the Xvid codec
http://www.roeder.goe.net/~koepi/xvid.shtml The first link
These are the only 2 codecs I have on my computer and can play every downloaded movie I have. They are really the only 2 you mostly need. But get rid of the Nimo pack, it caused problems for me and as I have read many others too.
as to what is RGB
http://www.adobe.com/products/premiere/pdfs/dvprimer.pdf
and I am assuming the DX50 = DivX version 5.0
If you still have problems https://www.videohelp.com/forum/viewtopic.php?t=138684 the link that says KingJohns Guide to Codecs V2 though the link is dead at the moment. -
Thanks Don......thats what I did....uninstalled the nimo code pack....it seems to help a lot of things.........
HC Encoder -How to open AVI files
By MI6 in forum Video ConversionReplies: 6Last Post: 30th Nov 2010, 15:15 -
VirtualDub won't open divx movie
By shmish in forum Video ConversionReplies: 9Last Post: 15th Mar 2010, 08:54 -
RMVB to DIVX (Cannot open file)
By leogeo in forum Video ConversionReplies: 5Last Post: 24th Nov 2008, 22:14 -
cannot open avi file
By ione in forum Capturing and VCRReplies: 8Last Post: 14th Sep 2008, 22:02 -
Can't open AVI clips
By sndfx69 in forum Newbie / General discussionsReplies: 5Last Post: 28th May 2007, 21:17
