I am trying to figure out how to convert divx/avi format to VCD. Ive tryed most of the advice in convert section of vcdhelp.com they dont work.
I was wondering if some one knows of a program that will convert them.
Ive tryed TMPGEnc Plus Version 2.58 it keeps giving me illegal stream format. the movie file plays on divx 5.0 player. I am just needing some help anyone has any advice?
Thankz
EE
Normally, TMpegEnc should give you absolutely compliant streams. Maybe you have not set all the parameters according to the VCD standard?
Video
Frame rate: 23.976, 29.97 (NTSC) ; 25 (PAL)
Frame size: 352x240 (NTSC) ; 352x288 (PAL)
Encoding: MPEG-1
Audio
Sampling rate: 44.100 Hz
Bit rate: 224 kbps
Encoding: MPEG-1 Layer 2
Remember also to properly resize your video. I always use 352 as width, then calculate the height with the formula
(source-height/source-width)*352. After that I letterbox the video to fit the 240/288 pixel standard height.There are only 10 types of people in the world:
Those who understand binary
and those who don't.
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 28th Aug 2008, 23:33 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 00:17
