  1. Banned
    Dec 2002
    Somewhere I belong
    Is it possible to make a subtitle so you can watch it in vcd but not like this:
    I like to eat pizza and carrot,what
    about you Gizmo?Do you like carrot
    and pizza?I buy one for you.
    I want to see the subtitle like seeing the movie in the computer like this:
    I like to eat pizza and carrot,what about you Gizmo?Do
    you like carrot and pizza?I buy one for you.
  2. i edit my subtitles with subtitle workshop while watching the movie/subs with subsync (but you can just use subsync). if the lines in your subtitle are divided with the "enter" key, yes you can fix them.
  3. Banned
    Dec 2002
    Somewhere I belong
    Have you tried to make a vcd with subtitles,if you have then which font size do you had in it?
  4. i haven't burnt it yet and watched it in my dvd player, but i watched in my computer the mpg with subs after i frameserved from virtual dub to TMPG.
    i don't know th font size, actually i just liked so much the font ant its size from the subtitle that i got, that i didn't bother changing it.
    but just for you i went there in subsync to check it out, and it's MS Sans Serif, size 8. it looks pretty good for me.
  5. Banned
    Dec 2002
    Somewhere I belong
    Looking on the computer is good for me too but if I want to burn it to vcd,then I want big font size like Arial 26 cause I have widescreen TV and wan to see the movie from a long distance.
