What is the best resolution I can get with VHS input to a capture card?
The best resolution with a PC TV card capture.
and the best resolution I can get with a digital camera / firewire input..
thanks
John
1.your resolution capture will be only as good as your vhs tape quality.
2.same thing depends on how good your tv signal is.
3.this one is going to give you very good piccies and is what I would use of all thre you mentioned. -
I guess my questions should have been is
What resolution do you normally get out of a VCR / VHS
and the resoultion of ot a digital camera..
thanks -
I have a book that says 352X240 for vhs, and about 352X250 for High 8. Digital is just the way the information is stored on the tape, it dosen,t necessarily give you better resolution. Here is a link where you can find more info.
annoying question regarding tv broadcast resolutions and how they are done
By deadrats in forum Newbie / General discussionsReplies: 8Last Post: 14th Jun 2010, 15:39 -
Screen Resolutions
By ranosb in forum Video ConversionReplies: 4Last Post: 25th Aug 2009, 03:04 -
Capture resolutions?
By visionman in forum Capturing and VCRReplies: 6Last Post: 28th Jan 2009, 13:13 -
Question about aspect ratio and resolutions
By KMJvet in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Dec 2008, 20:01 -
Question about resolutions
By ShinKyo in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 09:44
Here is the link :P
