I want to rip my DVD to a high quality file (preferibly something that can be played back from Windows Media Player, like an AVI.) File size is not a concern. You see I use Media Edition For my Os and if I can Create a high quality AVI I will be able to choose movies from the menu driven interface that looks in a special directory on the hard drive.
As I said file size is not an issue. I just want to get the best quality and use the correct tools. Any suggestions?
Guradianknot is the best all in 1 tool to create high quality divx movies.
http://www.doom9.org/gknot-main3.htm -
If you just want to play it on your PC divx can offer very good compression whilst maintaining excellent quality.
Need advice on best capturing solution
By vitalic in forum Capturing and VCRReplies: 22Last Post: 15th Feb 2011, 14:11 -
Looking around for a solution to this problem.
By chrisyroid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th May 2010, 09:44 -
Help me find the right solution please.
By abeaty in forum Video ConversionReplies: 8Last Post: 7th May 2010, 23:12 -
4:3 and 16:9 on same DVD - solution
By sergem1 in forum Authoring (DVD)Replies: 6Last Post: 15th Jan 2010, 03:03 -
Need Streaming Solution
By jadude in forum Capturing and VCRReplies: 1Last Post: 6th Oct 2007, 19:17
