I am having a problem using the header trick. I have a bin/cue SVCD and my player doesnt support SVCD so I was goign to use the header trick. Every time that I use TMPGEnc to change the header, the audio is off by about a second. The file that I am using the header trick on is the MPG in the SVCD bin/cue. Any suggestions?
Hi had a similar problem with the header trick. Was using the TMG method setting the Type to MPEG-1 Video-Cd (Non Standard). The Cd's played fine on my P.C. but was getting time delay / jumping problems with my panasonic DVD player. I then read another conversion guide which sugested using MPEG-1 Video-Cd as the video setting in TMPeng tried it an sorted perfect video.
on mine i'm getting audio....but no video and i've tried both vcd and vcd non standard...have u ever come across this?
MPEG-2 TS PAT header decoding problem
By jeromedroz in forum ProgrammingReplies: 21Last Post: 27th Jan 2016, 04:02 -
151MB mp4 file - with header problem?
By supermaster in forum RestorationReplies: 7Last Post: 6th Jan 2012, 08:52 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 11:23 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 16:21
