  1. I have converted my DVD to divx. But the quality is poor. I use DVD decrypted to rip, and Viodmi to convert to divx. When I playback it Seems to pixelate. The machine I use is a monster so I know-it's not a speed problem. Is there a setting to make the quality better? I don't care about file size, It will be stored on a Large hard drive.
    Dec 2002
    Orlando area
    First off, you should set your monitor settings to 32 bit True Color. Check your Divx configuration, go to programs >Divx> Divx Codec > Decoder Config. If your pc is a monster, just check your quality settings and Postprocessing settings. Also , try doing a 2-Pass compression or a 1-Pass Divx Quality. Vidomi is an ok program to me, but I would seriously RECCOMMEND Hersoft Video Convertor. An very easy to use convertor.
