I am using SpruceUp to author a dvd that consists of about 10 different m2v files. When I finished, I tried it on pc and standalone. Everything played ok except for the fact that the different tracks didn't play continuously one right after the other. It would play a track and return to menu, play a track and return to menu, play a track and return to menu. Is there a way to get them to play straight through. I know I can join them together with tmpg or something like that, but I always have trouble with the resulting file playing right( not to mention the audio matching up right and staying matched up). Any ideas??
I don't believe SpruceUp allows you to play them all without going to the menu first. I also use Impression DVD Pro and it will allow you to do this, so will other high end authoring programs.
Making a multi-track audio CD from a commercial concert DVD ?
By MacPCConsultants in forum AudioReplies: 11Last Post: 2nd Jan 2012, 09:26 -
How to convert mkv to dvd with multi-audio track and multi-subtitles?
By funnybunny in forum MacReplies: 1Last Post: 6th Jul 2011, 14:21 -
Looking for Multi Track Sound Editing
By HoosierGuy in forum AudioReplies: 9Last Post: 4th Jun 2011, 21:58 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 12:16 -
Multi Track Recording - Out of sync?
By GT Music in forum AudioReplies: 3Last Post: 30th Jul 2008, 15:44
