Hey guys,
I have been using IfoEdit to make NTSC movies, however it seems any movie which uses 3:2 pulldown causes problems with dvd players (Ie. a Pioneer 343). This is because IfoEdit can't handel the 3:2 pulldown flag correctly so any player which plays stricktly standard DVDs will skip and pause when fast forwarded.
Anyway, I know on a SVCD you need all the bitrate you can get so a 3:2 pulldown is important. However, on a DVD when you have a adverage of 5500 and a max of like 8802, Will a 3:2 pulldown really make a diffrence? If not I suppose if you use IfoEdit, you can always keep disks compatable by not using the flag. But if the quality from its use in DVD is great, it might pursuade some people to make non-standard disks which work with less players, but higher quality.
Any suggestions would be great, since I am at a loss if DVD really needs 3:2 pulldown anyways to show visible quality improvments.
Results 1 to 1 of 1
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Increase the bitrate---> Lose Quality?
By mark63534 in forum Newbie / General discussionsReplies: 10Last Post: 21st Jul 2010, 13:36 -
High Quality At Low Bitrate?
By sanosuke in forum Video ConversionReplies: 4Last Post: 4th Apr 2010, 08:21 -
question about 25 to 29 frames pulldown
By mazinz in forum Video ConversionReplies: 2Last Post: 15th Jul 2009, 12:58 -
A question about pulldown
By Talayero in forum DVD RippingReplies: 8Last Post: 7th Sep 2007, 12:37
