I have an audio sync problem in my MPEG file and i saw the guide
http://www.vcdhelp.com/sync.htm
and decided to use it. However, when i come to the part where it says to open goldwave and open the .mp2 fle goldwave tells me that
"Could not write data to disk. Make sure there is ample free space on the disk or change the temporary folder setting."
I changed the temp folder to a disk size that has like 1.8 gigs free on it but it still gives me the same error. I Changed it through Options-> File
I cant get it to open. Is there any other program or tutorial that can help me to fix the audio sync problem in the MPEG file without having to use goldwave? Or can someone tell me why this error keeps popping up?
THANKS
Results 1 to 1 of 1
Audio out of sync after editing in MPEG Streamclip
By Rhymester in forum EditingReplies: 0Last Post: 7th Nov 2011, 06:03 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
MPEG Streamclip audio sync issues
By notachancegp in forum Video ConversionReplies: 15Last Post: 3rd Dec 2010, 10:09 -
Sync audio starts-ok but near end 1 sec lag H.264/MPEG-4 AVC AAC LC
By JoeBolden in forum Video ConversionReplies: 6Last Post: 7th Jan 2010, 15:31 -
MPEG to Divx audio sync problem
By starless in forum ffmpegX general discussionReplies: 8Last Post: 11th Oct 2007, 05:38
