im creating xvcd and using the unlocked template. on the Rate Control Mode, which one should i pick, vbr ? cbr ?. i want the best quality and don't know which one to pick, plz help. thanx in advance
Well even though xvcd is bound by no standard, vbr is pretty non-compliant. VBR would yeild the best quality but there is a better chance that your dvd player wont be able to play it. To be safe you should use cbr, if you want maximum quality do a test encode in vbr and see if your dvd player can handle it. 2-pass vbr yields the highest quality and with a bitrate calculator you can find out the exact settings to use to totally fill up your disks.
ffmpeg rate control
By diprotic in forum Video ConversionReplies: 2Last Post: 15th Oct 2011, 22:35 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 12:53 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 20:48 -
Selectable Output Control - MPAA's new control tactic
By akrako1 in forum Latest Video NewsReplies: 2Last Post: 7th Aug 2008, 21:05 -
Having issues with Clone Mode in Catalyst Control Center...
By Jaxel in forum ComputerReplies: 1Last Post: 25th Feb 2008, 05:08
