Greetings,
I recently just found out about VCD's and I wanted to try it out. I followed this complete guide
http://www.vcdhelp.com/divxtovcd.htm
and I still have a sound problem. The sound only comes out of the left speaker of my tv. Nothing comes out of the right. When I turn the balance of the sound to the right... the volume just goes down. What could be my problem?
Results 1 to 10 of 10
In Virtualdub check the File > File Information...
In the audio section does it say 2 channel stereo?
If you play back the original Divx on your computer is it on one side only?
if so.....other than downloading or obtaining another copy,you can convert the audio to mono in Virtualdub by:
File > Open Movie > Audio > Conversion > Mono > Audio > Direct Stream Copy > Video > Direct Stream Copy > File > SAve As AVI"Today is only yesterdays tomorrow" -
It works fine on my computer, Comes out both just fine. When I go put it in the dvd player it plays yet it only comes out the left speaker. Not the right. I have tried this with about 5 movies. Same thing. But when I turn the dvd player off and go watch tv, the sound comes from both speakes.
Ah...sounds like a wiring or connection problem with your DVD player....
Put in a store bought DVD and see the results.."Today is only yesterdays tomorrow" -
As I said...if you try a store bought or rented DVD...what does it do?
I try my Lord of the Rings and Matrix store bought dvd's and they work fine... must be my dvd player I guess
Any recommened dvd players that play VCD's really good?
Originally Posted by NeonStryder
I find it really starnge how you can play them ok on your computer but only on one channel of your DVD player??
Try an experiment.
If you have a CDRW disk,record a 5 minute encoded video..
then try a short song in WAV format(audio CD) and see how they play.
Don't waste anymore CDr until you have it sorted out."Today is only yesterdays tomorrow" -
Tryed it still nothing. The sound still only comes through left tv speaker... nothing through the right... tomarrow I plan on going down to my friends house and trying it out there...
rmvb to avi, sound syncing problems, any tips or tricks
By dudeboy in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 08:19 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
sound problems
By deebo in forum Software PlayingReplies: 4Last Post: 9th Aug 2008, 14:43 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 20:21
