A couple of questions -
Is there anyway to preserve the Date/Time stamp following capture and transfer to a DVD or VCD?
I find it difficult to capture large (time wise) digital movies from a camcorder. Most programs tend to lock up. Any suggestions?
Thank you! :P
MjBart
Leawood, KS -
if your working with DV/Firewire, the date/time/data code is always stamped on the DV-AVI stream that was transferred to your harddrive. However, placing it on to the video so you can see it when you watch these AVI files is a different story. I don't think there's anything out there that will do just that. My suggestion, is you use your editing software's titling feature, and place a title on the video with the date on it.
I'm assuming you've reached the 4GB limit on your second question. If not, pls provide some more detail to your problem. If you are crossing the 4GB limit, you might want to use a capture software that allows for 'seamless captures', or better yet, consider upgrading to an OS that works with NTFS (XP, W2K).
In regards to your second question, I also suggest you do a search here, as you'll probably get tons of threads about that.
hope this helps. -
Jtor - Thank you for the response. It was helpful.
I think my problem is the 4Gb on long tapes. I do use xp, does it not care about the 4Gb limit?
MikeMjBart
Leawood, KS -
XP can get you around the 4GB limit, if the drive you're using is an NTFS partitioned drive. If it's still FAT32, then you need to make the switch to NTFS.
Out of curiosity, how did you get the video files to your PC (what software did you use)?
Analogue to Digital capture software
By ManUtdFans in forum Capturing and VCRReplies: 9Last Post: 16th Jun 2011, 12:10 -
Converting for digital movie download
By JeDxW in forum Video ConversionReplies: 17Last Post: 26th Dec 2010, 10:38 -
Movie Download from Digital Camera too Dark
By harrija5 in forum RestorationReplies: 1Last Post: 18th Nov 2010, 08:54 -
burn digital camera movie to see on TV
By joyce batchelor in forum Newbie / General discussionsReplies: 4Last Post: 18th Oct 2007, 19:04 -
resolution on movie nero digital
By krain_l in forum Newbie / General discussionsReplies: 3Last Post: 25th Jun 2007, 00:49
