Can TMPGE be set up to convert mutiple avi's one after another with no imput from the user. Would like to convert a bunch of avi's without having to do them one at a time.
Thanks............
Batch encoding is the answer for you. Instead of hitting the start button for encoding, simply Save Project from File menu (in .tpr file) After you created all .tpr files (one for each AVI), then go to File -> Batch encode, select all the .tpr files and hit 'Run' button (and then go to sleep).
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
cutoff of avi conversions at about 80 min
By jpp2009 in forum ffmpegX general discussionReplies: 0Last Post: 9th Oct 2009, 13:57 -
Help with multiple conversions
By Hoover40 in forum ffmpegX general discussionReplies: 1Last Post: 13th Sep 2008, 23:14 -
DVD to AVI Conversions Shutting Down System
By RolePlayArtist in forum Newbie / General discussionsReplies: 2Last Post: 1st Jan 2008, 12:35 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28
