Hi
I am capturing with Virtual Dub from VHS source, to encode it for SVCD with TMPEGEnc, and I have a question:
What audio parameters are the necessary for SVCD, 44 or 48 KHZ?
I have problems capturing above 352x288, Virtual Dub gives me the next error: "Video Format not compatible".
I have PCTV Rave and I have read in the manual that support 640x480 (for example)...
Thanks a lot
i have autoanswered me the question about the resolution, but i dont know if i have to chose a specific khz audio frequency for svcd or the one i want.
Please help me
thanks!!! -
You can use a 48000 sampling rate for SVCD,44100 is spec.,but if your DVD player will support SVCD with 48000 it's ok. I've tried 6 different DVD players and they all except 48000 on SVCD. Most DVD will support 48000 on SVCD because 48000 is the standard for DVD.
Unless you have a good reason (e.g., plan on migrating your video files to DVD at some point), stick to 44.1 kHz sampled audio. There is no point in making something trivially off spec as there are some players that don't like 48 kHz audio on SVCDs.
Regards.Michael Tam
w: Morsels of Evidence -
umm i am really confused with the spec of Super Video CD. I have downloaded the specs from philips, and they say SVCD support variable bit rate for video and audio (and in some sites i have read that not). So I can use VBR audio with SVCD? The correct bit rate to use are 64-384kbps I am wrong? Can you recommend me a MPEG-1 layer II encoder that have good support for VBR? (For what I have read TooLame is very fragile in VBR)
Another question, can I use mono instead of stereo in SVCD?
Thanks! -
I think you can use both VBR for video and audio. However, VBR for audio may not be well supported on many stand-alone players. It is probably safer to stick to CBR for audio. You are not going to save much space anyway.Originally Posted by IrYoKu
Mono? Yes, you can for SVCD.
Regards.Michael Tam
3d questions
By alucard2050 in forum DVB / IPTVReplies: 16Last Post: 22nd Aug 2010, 00:01 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 19:08 -
SD to HD Questions
By The Sumerian in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Nov 2007, 12:08 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
