Hi all!
I have been trying to burn a few SVCD bin files, to no luck whatsoever.
I have first used Nero 5.5.8 to burn the bin directly - I get no size errors when it starts, but when burning, the progress bar hits 100 but the burning never ends - the lights on the drive keep flashing and flashing. It's not just closing the disc, as I have let it sit for an hour after it hit 100...
I then extracted the mpeg using VCDGear and tried to burn a new SVCD using Nero again - no luck...
I tried burning the SVCD using NTI 2000 - no luck - same results...
I tried building a new SVCD image using VCDEasy - using Daemon tools, I can see the SVCD structure is correct, and playback the SVCD using Media Player, but it won't burn correctly either.
I have upgraded Nero to 5.5.10 - same results...
I have even tried new brands of CDs - all 80 minute discs - no luck
I know that I can burn SVCDs - I had luck once extracting the mpeg and reburning that - but now, nothing
Does anybody have any suggestions for me?
Thanks!
I know you mentioned that you get no size errors but the same thing happened to me the other day because I treied to over burn just a few secinds more than I should in NERO. The Lead out could not be written and I had to restart my PC to open the drive. The funny thing was though that the SVCD played perfectly anyway! It must have been an error right at the very end of the write process. Probably doesn't help but there you go...
GGS.Eat! Drink! Be merry! Tomorrow we snuff it! - (Sid James, from 'Hancock's Half Hour')
Joining MP4s ends up as VFR
By douga in forum EditingReplies: 0Last Post: 8th Jun 2011, 12:46 -
Burning DVD issue with Sony HDR CX 100 (PMB software)
By jungleeravana in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th May 2010, 00:43 -
Dazzle Digital Video Creator 100 (DVC 100)
By Rockin Rayzor in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2008, 17:08 -
Conversion ends with NO-FILE
By Tobias0815 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jun 2008, 05:31 -
DVD+RW ends up useless
By woodlander in forum Newbie / General discussionsReplies: 1Last Post: 25th Sep 2007, 12:32
