  1. Hi!
    I have this DivX file...
    all is good - but the sound is not synchronized with the video...
    you can see the man talking - but you hear him after 2 seconds...
    what to do?
    May 2002
    Rainy City, England
    Is it a constant synch difference throughout? If so, load into Nandub. Set audio and video to direct stream copy. Then adjust audio>interleaving>audio skew correction, and save to a new avi.
  3. what ???
    it's one file... that is all i know...
    May 2002
    Rainy City, England
    I asked if the audio delay was 2 seconds throughout. If so, you should be able to fix it as I suggested.
  5. i have 1 divx movie which download it by kazaa and the saund was delay 7 sec can it fix with this method.and how to set the interleave value ?
    May 2002
    Rainy City, England
    You can if the delay is constant. Otherwise it gets more complicated. If it's due to errors in the DivX then sometimes it's not worth the effort trying to correct the problem. Try it and see. If you downlaod Nandub, the interleaving adjustment will be obvious. Then it's a matter of trial and error to see what adjustment you need to make.
