hello,
I am new to dvd authoring and this forum so i am sorry if its been posted before.
I want to make a dvd with menus, but i want to use lots of mpegs. I tried to do this, but ran into problems. When i authored it the mpegs could only be added as chpters and not scenes, so on my dvd player the numbers will not work, i.e. press 5 to get to track 5, etc.
What i want is lots of small mpegs, and go to the one you like through the menu's and using numbers on the keypad...i an guessing that they must be scenes and NOT Chapters, but i cant seem to do this.
I tried using ulead workshop and ulead movie factory. My files are all converted, ready and witing too so thats no problem.
Does it mean i have to 'stick' all the mpegs together, then cut them up in movie factory as scenes?? is there not an easier/quicker way?
Thanks for your help in advance![]()
how do you create "true chapters"? the help guides on the site says: "Note! This chapters are not true chapters where you can use the skipforward and skipbackward buttons on your remote while watching, this chapters are only selectable from the menu."
So how can you create true chapters using one of the ulead tools? i have searched the site and forums with no luck
plz help -
You cannot use the numbers on the remote to select chapters on DVD's this only works for VCD's and SVCD and their variants. To select chapters on a DVD you need to create a menu and highlight the chapter you want using the cursor keys then press the enter button.
Look at VCDEasy software. It will do alot of the chaptering for you. Burn it on CD-RW first so that you don't create coasters and play with the settings...especially with the "interactivity" tab. The best part about it is that its free!
The itsy bitsy spider climbed up the water spout. Down came the Goblin and took the spider out. -- Spider-Man, 2002 -
isnt that for just making vcds? (if not they really should change the name
I cant burn to a cdr, as i want to use 30+ mpegs which will be too big for a cd. -
FreeFall,
Ulead DVD MovieFactory 2 will do what you want. Each seperate MPEG file will create a thumbnail on the Main Menu. If you want chapters for each mpeg, DMF2 will create a submenu off of the main menu for chapters.
Dave -
Originally Posted by Craig Tucker
Originally Posted by FreeFall
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 04:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:16 -
Portable APP to save mpegs from a DVD?
By bigMach™ in forum DVD RippingReplies: 2Last Post: 12th Nov 2009, 08:07 -
playing mpegs on a dvd player
By fromunda kid in forum Video ConversionReplies: 8Last Post: 9th Mar 2008, 12:30 -
Extracting MPEGs from defective DVD's
By TPFKAS in forum Video ConversionReplies: 3Last Post: 26th Sep 2007, 02:01
